Two NOOB questions
narsbars
I have an Asus board, SLI capable, M4N98TD EVO, what kind of vid cards am I forced into using if I want to use dual cards? As soon as someone tells me NVIDIA, I can scream as I just got a new 5770.
Second NOOB. This board was a dream to set up BUT, being lazy I grabbed a HD with Win 7 64 bit already on it and plugged it in. The result is that everything works except the NIC. It is not the NIC as I can get to the web using Express Gate.
I can't seem to find the right drivers to install. Any help gladly accepted. Help accepted even if I get laughed at.
I've got some bad news about the video card. You do have to use nVidia cards on that board if you want to run dual cards. The board uses an nVidia chipset and they don't allow Crossfire.
But, if your monitor is running at 1920 or less, sell the 5770 and use the money you were going to spend on a second card and buy a GTX470 or a 5850. Both will give you all the performance you need on 1920 or lower with a single card.
About the NIC, what is it showing in the device manager? How you handle this is your call, but if it was a choice between screwing around with the onboard nic for more than an hour or buying a PCI NIC for $20 at Office Depot and plugging it in, I'd take option #2.
Thanks, I was hoping I was wrong about the vid cards, but up to now my gaming has been happy with a 4850, ddr2, and a 940.
I am up to a 965 and DDR 3 now so I should be OK even if the 5770 is just a little better than the old 4850 at 512.
As far as the nic, I have a spare nic but this is a software issue and is p ing Me O and even if I have to put in a nic card I intend to solve it. The trouble is the Nic card seems to be identified as one that Asus doesn't use (AFAIK). I can't find the exact chipset listed on the ASUS site.
Thanks for the help.
If it's a realtek chipset or a marvel chipset on the NIC which most onboard NICS are. Get the chip number off the chip itself and go to the respective website and download the driver from there. This is what I had to do with my Gigabyte board that uses a realtek Chipset.
Sound of man smacking himself in the head!!!! Duh, read the chip, get the driver! I am certain it must be a realtek driver as most of the rest of the recent Asus board seem to be realtek.
Thanks for reminding me of something I should know. Appreciate the help
if its a nvidia chipset.. the NIC drivers should be part of the nvidia chipset drivers when you install them which is probably why you arent finding anything on asus's website.. being that the nvidia 980a chipset is identical to the 780a chipset im sure you could also find the nic drivers on a similar 780a asus board..
NIC drivers should be included on the driver disc that came with the motherboard.
The drivers are there, and they might work on a fresh install, but I found that the Nforce drivers do not work at least when using a HD with a previous copy of Win 7.
I did a repair install of Win 7 64bit on one HD and the Microsoft drivers were installed and recognized. I then tried the same thing on a 32 bit HD and the Nforce drivers stayed and were recognized but don't work.
I am going to do another pass with the install disk, and another pass with an in place repair install........who knows?
Why not do a fresh install of W7, then go to the ASUS website and download the latest drivers for the chipset,audio and NIC?
As someone else said, you have an nvidia chipset.....NVIDIA nForce 980a SLI® ......heres the chipset link: http://www.nvidia.com/object/nforce_vista_win7_32bit_15.49.html
The NIC is a Broadcom® B5071 Gigabit LAN Controller featuring AI NET 2
Heres the scooop from the ASUS website: http://www.asus.com/product.aspx?P_ID=1g8o5Sh3csqM5M8u&content=specifications
Oh man, I sold him the board. As annoying as it may be, windows does save your old OS files on a fresh install, so you don't even need to backup. Also have you tried the driver sweeper from guru3d? Some old drivers may be conflicting w/ the nic. It may be worth a shot
I have so many programs installed and I am missing some of the keycodes so I am taking the easy way out, at least I thought I was taking the easy way out.
I have done two in place upgrades and at least the add on wireless card is working.
I am heading over to Guru3D for the driver sweeper.
Since the NIC does work and I know this is some whacked software setting, I am going to beat on it until it works. Thanks to everyone for all of the help. I would never have gotten this far without some of your ideas.
