two NIC shows up?
badteddy
hey guys, i just popped in my Network card (PCI) and then i install drivers for it.. so now two shows up...? what could be the reason.. i thought it was just a regular 10/100 ethernet card.. but why does the gigabit ethernet thing shows up? the NVIDIA is my onboard and i dont wanna use it.
im testing to see if my onboard one is having connection problems. but now im confused as to why two of the Realtek drivers show up from just one card..? when i plug in the ethernet cable.. it only shows connection to the fast ethernet NIC and not to the gigabit ethernet.
It might be using a different driver for Gigabit... although I wouldn't think it would.
Have you tried deleting the Fast Ethernet one out and seeing if the Gigabit would work?
ya.. i believe so i disabled the fast.. and then plugged in the cable.. nothing.
UNINSTALL the fast ethernet device from Device Manager. See if it works.
