Is there some reason what I am trying to achieve does not work?
I have one cat5 cable running to a room. I want to send two independent ports to this room over the one cable...i cant run a second cable run at the moment.
So since 10/100 only uses two pr to send data I tried to take one jack and run two cables to it. Running one cable's T+,T-,R+,R- to the the normal pins and then another cable's T+,T-,R+,R- to the unused pins. I did this on both sides the same way.
I connected everything and it's a no go. What am i missing? I don't think I have any inconsistancys in my wiring but i'm testing continuity now.
