Two Monitors as "one" screen.
Johnsen
Hi guys, i have tryed to figure this our for two days now. Is it possible to make 2 1920x1200 monitors to work as one 3840x1200 display, if so - how? :)
Ive got two HP LP2475W IPS monitors and a old geforce gtx 560 ti.
:D
rtangwai
Doesn't the 560ti support nVsurround? That would make the video card present the two monitors as one big one to Windows (similar to AMD's Eyefinity).
suiken_2mieu
It used to in the days of XP, but they removed the feature in 7/8. In order to use surround, you need 3 monitors. So, if Johnsen is using DirectX9 applications, softTH would be the best bet.
