Two identical HDs and two different sounds?
JimmyNeutron
Hi,
Computer 1: Intel D975BX2 - using 2 WD5001ABYS SATA hard drive in non-raid mode
Computer 2: Asus Rampage - using 2 WD5001ABYS SATA hard drive in Raid1 mode
When transferring data from Comp#1 to Compu#2 via ethernet, I can hear the hard drives in #1 pretty loud. Well, loud compare to the two WD5001ABYS hard drives in Comp#2.
All four have the same manufacturing date of Feb 25, 2008. Is this normal?
Thanks!
Are the drives in the same case? Are they mounted the same way?
I'm going to go on a limb and say its your environment making the drastic difference. However my Seagate drives don't all sound alike. I wouldn't worry unless you are experiencing more apparent issues or if the sound is not only louder but abnormal.
They are in different cases and all are mounted horizontally. I'll do a surface scan just to make sure there are no bad sectors.
Thanks!
