Cyber Akuma
- Jan 3, 2009
My motherboard is an Asus P8Z77-V Deluxe, and my case is a Cooler Master HAF X. Not counting the CPU fans, my motherboard supports headers for an additional 4 case fans.
The HAF X lets you put in several optional fans, I decided to use some of these for better airflow due to the large amount of drives that will be in the system.
Two of them pretty much serve the exact same purpose, they are exhaust fans that push air out the top of the case. And while I do have a 4-pin header for one of them, I don't have one for the second. I know there are cables out there that let you connect two 3 or 4 pin fans to a single header, but I know these these have problems.
First of all, ones that have all pins for both fans tend to confuse the motherboard by feeding it two RPM monitoring signals at once (Again, since they both serve the same purpose and are in the same location, just motoring the RPM of one of them and adjusting both accordingly at the same time is good enough). So I am guessing I need to keep an eye out for a cable that has pin 3 missing from one of the two fans it connects to right?
Second, would the motherboard be able to supply enough power? They are two 200mm fans, and both have leds as well. I couldn't find information on how much power the fan headers on my motherboard supply, or how much the fans use (Cooler Master Megaflow 200).
I know this is kinda a long shot but, does anybody have any idea if I would be able to connect two of these fans to a single header on my motherboard?
