Two different O/S on the same network?
whatsup everyone?
Quick question. I have an HP running XP and a Compaq running Vista. Could I run both of those on my network so I can share files between both computers, but only have the Compaq have access to the internet?
you'd probably have to set up IP addresses manually in order to do this. If you don't plan on using a router or switch, you'll also need two network cards in the internet enabled PC. (unless you use a USB connection to your modem)
In general home machines use an IP address of 192.168.0.X - subnet mask of 255.255.255.0 - and a default gateway of 192.168.0.1..... if you don't want internet access... simply don't provide a default gateway
It is fairly simple to setup. Assuming you are using a router with dhcp, allow the Compaq to grab in IP from it. On the other machine, set the IP manually, and leave the gateway address blank. With no gateway address, there is no internet access, but you can still access it on the network.
