SkaarjMaster
- Jan 31, 2002
I just setup my new XP computer and in order to access the Internet I just unplugged my ethernet from back of old computer and into new one. It connected to Internet fine and I did the Windows update with no problem, but I noticed a few things:
- keep getting Vtruck.exe error with RoadRunner everytime I reboot new computer
- Host names of computers are different
- DNS Servers are the same
- Adapter (Physical) addresses are different
- IP Addresses are different; probably because it was a different computer pinging and Roadrunner assigned a new IP address to new computer.
- Subnet Mask, Default Gateway and DHCP Server are all the same between the two computers presently.
Tonight I plan to hook up the router (Linksys BEFSR41) and the router instructions say to first configure each computer to communicate with the router, then the router with the ISP. As you may already know, I have a few questions:
1. Will this Vtruck.exe error go away once I have everything setup? If not, how should I get rid of it? I tried links through google and nothing seemed to help.
2. What has to be the same between the two computers in order for both to connect to the Internet through the router?
3. To configure each computer to communicate to the router, do I need to have everything on and connected or temporarily disconnect the router from the cable box?
4. To configure the router to communicate with the ISP, I would like to go through the new XP computer. Is this a problem or since I've used the 98SE computer with the ISP for so long should I configure through this one instead?
5. I also want to plug the XP computer into the 1st slot on the router and the 98SE into the 2nd slot. Does this make any difference as well?
Thanks for any help.
