Two channel system + Eyefinity issues...
TotalLamer
So I certainly plan in the future to be running Eyefinity... I've got 1 HP LP2475w so far, 2 more to go. Of course, this results in a bit of an issue... obviously speakers can't go between the monitors, and if I put them beside the side monitors, they'd be more like surrounds than primary front speakers... playing from my sides. So I figure what I can do instead of buying traditional bookshelves is buy a pair of center-channel speakers and position them beneath the side monitors. Thoughts?
What about speakers mounted above the LCD screens and angled down to your ears?
or below them
another idea is to have the monitors is portrait mode, will narrow it and make speakers on the sides work ok
honestly if you don't sit right on top of it, having them at the sides of all 3 in landscape won't kill your sound, if they're angled right
might also consider headphones
