I was just curious if anyone was able to stick dual 240 rads in a v351. I looked around a bit and have seen people easily fit one in there. I'd like to do it all internally but am not sure if I can fit it. I have a P67, 2500K, a HDD and SSD. I currently have one 240 mm rad in the front, but was thinking about adding another and putting my 6950 in the loop as well. I'm thinking about putting the second rad where the HDD cage is and drilling slightly into the 5.25 cage, but then I'm not sure where to put the HDDs if I do this. Also, would an XSPC rasa kit pump/res combo be sufficient to power the 2 rads, the XSPC rasa CPU block and the GPU block?
Thanks!
Thanks!
