TWINX1024-4400C25 Issues!!
mogman42
Recently I built a new system with the following parts:
Abit IC7-Max3 bios ver 1.7
Corsair 1GB TWINX1024-4400C25
Tagan 480watt power supply
Intel P4 3.2Ghz Northwood 16x200
I am having issues getting the memory/system to run reliably above 200mhz (DDR400). I've tried the appropriate dividers to leave the CPU stock while raising the memory to 250 and 275 respectively @ 2.8v
The system will boot with the following settings but reboots right at/after the windows splash screen.
4:5 ratio
200/250
CPU default voltage
Mem voltage 2.8 no setting for 2.75
Mem timings set by SPD are @ the approved 2.5-4-4-8
I tried running Memtest86+ v1.30 will the following options
Test All Memory
Extended Tests
On test 8 I received 4110 errors. I rebooted with one stick @ a time and tried to duplicate the error, but have been unable to duplicate with either stick. However, I still cannot get the memory to run anywhere close to its rated speed.
Please help!
