Twinmos pc3700 2x512
Viet15philong
Bad Trader
I just bought these ram and was wonder will they work with NF7-S ver. 2!!! Plus are the win-chips, ch-5, bh-5???? Plus Is it good!!! Here is the linkTwin Mos 2x512
They are Twinmos chips usually. Timings on them are 2.5-3-3-7 as far as I know, but with a bit of voltage they should be able to do 2-3-3-5 or 2-3-3-11 depending on what you prefer. I recommend you find some BH5 based memory for that NF7-S, its the only way you'll be able to hit 2-2-2-5 or 2-2-2-11, which should give the best overall performance.
If they are BH-5 chips you might be able to go 1:1 to 250 mhz on the fsb ;)
Highest I've had mine is 235 mhz
so this memory is no good?? plus can i reach 2-3-3-5 or 2-3-3-11?? with the one i have???? Pluz Which one is better the setting??Pluz I have one corsair CMX-3200CPro!! wat is the settings on that!!!What is the best?? Should i sell the Corsair chip or the twinmos
