Ok after fresh install of Vista Ultimate x86 i thought i would try out tversity again to stream media to my PS3, so i followed a PS3 guide and at first it didn't seem to work at all everything installs and says its working but when i tried to add files, or change settings with GUI it would say the server isn't running, so i tried everything same error message so i got fed up and went to play some games on my PS3 but didn't shut down tversity.
so scrolling throught the XMB there it is my tversity server and i can see and access all the default folders and the G4 streams and what not, so i go back and add my media through the media share comand promt, it works it see F:\ my media disk, it sees all my raw ripped DVD files TV shows ect... so i go back to my PC and tversity still says the media server isn't running and won't let me access any of the settings or add files through the GUI but yet i was able to watch almost the whole 4th season of House with out issue, listen to music ect...
i have turned UPnP, i have tversity set to log as my account and not local service, i have network set to private, added exceptions to windows firewall i have tried everything i can find but it still says the server isn't running, now it clearly is because it is working but i can make any setting changes because tversity server isn't running.
So does anyone have any ideas on what may be the cause or something i can try because i am out of ideas.
System set up:
fresh install of vistaUL X86 SP1
hardware see sig
TVersity RC2
Codecs, Haali Media Splitter. AC3 Filter, FFD Show (no other codes installed or tried)
guide i used http://www.ps3forums.com/showthread.php?t=75081
System set up:
hardware see sig
TVersity RC2
