TV Wonder pro
TruthInRuin
On the ati website, it says that this TV tuner card lets you "enjoy up to 125 channels"
Is that the MAX, or if I hooked my cable box up to it would I be able to get all of the channels I pay for?
As far as the ATI tuner is concerned you will only tune one channel for your cable box- you will then get whatever the cable box is tuned into on the ATIcard. (ie you cannot tune the ATI card to change the cable box channels).
