I'm thinking about one of the 2 following pinnacle tuners:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815144027
http://www.newegg.com/Product/Product.aspx?Item=N82E16815144026
1st: Is the only difference between the two a remote? Or does the first not have DVR capability? It's kind of vague.
2nd: Do these work in Vista Media Center? I already have a generic media center remote, so if they do, I guess it would be better to get the cheaper one?
3rd: Can you connect DirectTV to these (using the 3 yellow, red, and white cables like you would with a console)?
