TV Tuner Question
Aeauvian12
I had a quick question regarding TV tuners. I'm moving into colelge, and I want to be able to record my shows on my computer. I need a tv tuner for it, and that's where i've run into problems.
I don't know whether to get a USB or PCI card. I know I want it to do onboard encoding, so either way.
I don't know yet if I'll run mythtv on a linux distro, or try the windows mythtv version. Either way I'd like a card that can support mythtv, and has a wide array of support for other such programs.
ANyone know what my best bet would be? I'm looking to spend 60-100$, but a little bit more is okay if it's within bounds.
If any additional info is needed, let me know.
I looked through the FAQ threads, and didn't see any related info that had sites that were still up, sorry if this is a repost :(
i happen to have a Hauppauge Win TV PVR 500 which is a dual tuner PCI card (watch one show and record another) with remote that is only about 3 weeks old that i am looking to get rid of because of a disagreement with the boss (wife).
I paid $165 for it new.....pm me an offer if you are interested
I would go for that, but it's a little over my price limit :( I've gotta keep expenses down so I have enough spending money to last me through this year
Ati Theater 550 is a good SD card. I use 2 of them with MCE. I'm not sure on linux support but its one of the best SD cards to buy. I think their around $50-60 for the PCI version.
I looked on the MythTV wiki and didn't see that supported. How are the Hauppauge PVR-150s? Anybody have one?
There about 5 years old. I wouldn't touch one with a 10' pole. I'm sure they work with linux but the quality is crap compared to what is out now.
The PVR-150's are old, yes, but still not bad. And, from what I've heard, they ignore macrovision, if that interests you.
How old they are doesn't exactly matter. He's using Linux, that limits his choices to pretty much the PVR150. Unless there are now linux drivers for the 550 and 650 based tuners he's stuck with a PVR150.
Alright. If I weren't going for linux, which would be the best for me in my price range? And if so, what windows alternatives (free, preferably) are there for mythtv?
Already been suggested; a card based on ATI's 550 or 650 chip. This is one that I'm using, I'm very happy with it.
http://www.newegg.com/Product/Product.aspx?Item=N82E16815310002
While there are a few solid (free) alternatives under Windows you don't want to go with one anyways right now cause, well, you're going to have to pay if you want it to do PVR work.
http://www.hardforum.com/showthread.php?t=1219149
Go with GBPVR. Lots of cool options for it. Including Gamezone which allows you to play MAME Roms, old Nintendo 64 games, Playstation 1 games etc etc. Its a cool program.
Did I mention its FREE!!
I use a Haupage 1600 as it supports QAM. Great picture on my 21" CRT, not so good on my 22" Widescreen LCD. Not sure if im doing something wrong there.
