I see it's 185.ampedxc27 said:you could get the radeon 2006 edition card, i'm not sure if it comes in agp, but its an all in wonder card designed for the media center edition and is like a 9600 so you might be able to game a little bit. it includes a tv tuner on the card.
Thanks!Logan321 said:Just FYI, the videocard isn't as important as the tuner, afaik. MCE requires a hardware encoding tuner card, and they are always more expensive. Having said that, you can get a 150MCE for about $65 USD if you shop around.
Case in point: http://www.newegg.com/Product/Product.asp?Item=N82E16815116620
So just those two things and two empty PCI slots and I am good to go with MCE?IDversusEGO said:MCE requires a hardware encoding tuner card and a directX9 compliant video card.
PVR-150 for $50 - http://www.pcalchemy.com/product_in...m-tuner-oem-pn-26692/cName/pvr-cardstv-tuners
fx 5200 for $40
http://www.newegg.com/Product/Product.asp?Item=N82E16814125191
if you are looking for on the cheap, try using mediaportal instead of MCE.
that's not neccessarily true. while your tuner DEFINITELY needs to be MCE compatible, you also need to make sure your video card (VGA adapter) is MCE compatible (mostly, that it's DX9 compatible) if you intend on using the TV out to display MCE on the TV. *Technically*, any WinXP video card will suffice to "get an image on the TV" but the quality of the image you get on the TV will most likely be unusable if it's not on the MCE approved list.Logan321 said:Just FYI, the videocard isn't as important as the tuner, afaik. MCE requires a hardware encoding tuner card, and they are always more expensive. Having said that, you can get a 150MCE for about $65 USD if you shop around.
that's not entirely true -- the PVR-350 from Hauppauge supports TV out. In fact, it support *hardware* MPEG2 decryption so long as the stream is going across the TV out port. And, SageTV (as of 4.x) supports outputting the SageTV interface to the TV via this port.vanilla_guerilla said:yea pretty much. your vid card will need win mce drivers if you are going to use it. a tuner card will not output video to a monitor. ....
Totally piece of crap, it's a 9600 series All in Wonder and you need ATI's special MCE drivers to get it too work since it's unsupported natively in MCE because MCE is suppose to work with only hardware based encoding cards.ampedxc27 said:you could get the radeon 2006 edition card, i'm not sure if it comes in agp, but its an all in wonder card designed for the media center edition and is like a 9600 so you might be able to game a little bit. it includes a tv tuner on the card.
It's a moot point, the only way a PVR350 is worth the money is if you're using Linux. Better drivers, stable drivers and MPEG 2 decoder and fully supported TV out (eg: you can output the whole GUI).svet-am said:that's not entirely true -- the PVR-350 from Hauppauge supports TV out. In fact, it support *hardware* MPEG2 decryption so long as the stream is going across the TV out port. And, SageTV (as of 4.x) supports outputting the SageTV interface to the TV via this port.
You might want to pick the MCE remote but yeah just those two things and you should be good to go (just so you know you have to have an MPEG2 decoder, make sure you select as an opinion with the tuner card for $10).Phrogg said:So just those two things and two empty PCI slots and I am good to go with MCE?
Edit: It has to be Windows Media Center because one it's already installed and two it's going to be streamed to my Xbox 360 when i get it.
where is that option?CrimandEvil said:You might want to pick the MCE remote but yeah just those two things and you should be good to go (just so you know you have to have an MPEG2 decoder, make sure you select as an opinion with the tuner card for $10).
