tv tuner for direct tv
Matt Samoohi
Can someone Please direct me to a good tv tuner around 100$ which can record tv from directv thanks. I dont want to get it from the dish i want to use the coax cable that comes out of the reciever and into the tv but instead i would like to put it in the tv tuner and not the tv. ANy help would be appriciated
Never mind. I got my tv tuner to be detected. Can someone help me set it up to directtv with beyond tv 4. Bercause whenever i put the coaxel on the tv tuner it still dosent show an image or sound but on my tv s input it does any help would be appriecioted
don't use the coax output, use either composite (single yellow connector) or svideo (small, round, looks like a mouse/keyboard connector.) I don't think BTV will tune a satellite source on the coax input. You'll also need to connect sound cables (red & white connectors) to the PC. Depending on which tuner card you have, the inputs will either be on the back of the tuner card, or maybe a breakout box.
After that, just follow the BTV setup wizard.
YES EXACTLY!. I have a purple cable that attaches to the back of the video card which has the yellow red and white inputs and a svideo input/output but the problem is on of the pins are bent do you think ati will replace the purple cable?
have you tried bending the pin back into place yet? Otherwise it may not even be worth contacting ati for that cable since it can be found for pretty cheap elsewhere.
You can compare the pins on these to see which is compatible with your card:
- http://www.monoprice.com/products/p...14&p_id=2513&style=&seq=1&format=1#largeimage
- http://cgi.ebay.com/NEW-AV-INPUT-CA...5QQihZ008QQcategoryZ40158QQrdZ1QQcmdZViewItem
Or just pick up the original here: http://cgi.ebay.com/ATI-All-In-Wond...ryZ40158QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
yeah i just bent the pin back im not testing it as in actally hookin directv up to it or anything till tomorrow but i hav ea slight problem. On brodcast source it gives
antenna anolog( shows a wierd thing with a circle and two antennas )
Standard cable ( shows coax cable)
external cable box ( shows a reciever.)
stalite ( shows a dish)
which should i choose
Matt Samoohi said:
so what should i choose stalite dish?
To do that? Don't bother since there isn't a tuner out there to that does that. You have to use the analog outs on the Dish STB to the tuner to record from one.
I think he's already hooked up using composite cables now. Seeing as there isn't albino wombat option in the wizard, I guess that 'satellite' would be the best option. ;)
tried it no luck but cnet did a review on btv4 with an ati 550 card AND direcrt tv y cant i get it done
