Hauppauge HVR-2250. Dual Tuners, OTA, ClearQAM and Analog.
how is that setup on the client end then? is it setup like a virtual video input or is it just like a webstream video?
I'm assuming you're thinking about hooking it up on your home network and watching it at work (or some similar situation). Given that you have enough bandwidth (I doubt you do!) to upload one or two HD streams, you shouldn't have a problem. I don't believe this is the intended purpose for the device, but it should work fine if you've got the proper forwarding at your router and enough bandwidth to do it. It's more meant as a LAN solution, but I'm not aware of anything preventing it from working over an internet connection.and, are you able to watch your channels over the internet, outside of your home network without much trouble?
