I'm looking into getting a TV Tuner card. Would I need to connect it to my GPU or anything? Would it be a matter of putting it in my PCI slot, pluging the coaxial in and then it's fine or would I have to connect it to my 8800GT via S-Viideo?
http://www.newegg.com/Product/Product.aspx?Item=N82E16815276008
Is that the best one for the money? I really don't want to spend over $45ish.
Thanks
Thanks
