I'm having a lot of trouble setting up my TV Tuner card. I have a hauppauge hvr-1600
http://www.pacificgeek.com/productimages/xl/5188-7111-CO-R.jpg
We have this black box which i'm told is the digital cable box.
http://www.motorola.com/Business/US...t-tops)/All-Digital+QAM+Set-tops/DCT700_US-EN
Essentially what happens is the Cable comes from Room 1, then it comes into Room 2 (my room). There it is split. 1 goes to my TV tuner card in my computer, the other goes to Room 3. I never had it plugged into the Digital box but i assume it will benefit me if i do?
I have the cable line plugged into the TV in.
As of now I have the digital box unplugged and set aside. I have it just run through a normal splitter. I then set up my card to scan for Digital ATSC as well as Analog signals.
For Digital ATSC it picks up 8 channels. All channels are in the thousands (1172, 1171, 1031, 1571, 1101, 1102, 1103, 1291)
Then it brings me to the analog tuner setup. Source is set to cable (instead of cable HRC or antenna). it starts scanning channels 1 to 125. but it doesn't find anything.
Any idea how to get this to work?
