TV out resolutions, which cable is best?
G'ßöö
am wondering if you get higher resolutions using a component cable to the tv over a s.video. I gave my component cable away when I didn't need it anymore so I cannot test this. the max rez I get is 1024x768 to my HDTV using a s.video. if I use a component will I get higher rez? ...am using a XFX 7800GTX
EDIT: its an older rear projection tv that does 1080i
Thanks in advance, G.
It's better quality for sure - I'm not positive about resolution, but I would think it would be higher as well. I know my HD DVR connects to my HDTV through component cables and it supports 720P and 1080i. I would think that a component cable could do 1080p also, but I don't know for sure. If you want progressive scan output, you'll have to use component cables, as S-video doesn't support it.
1024 is about the max for an s-video you will need a component or hdmi/dvi to get anything higher
1024x768 is the max resolution for composite (the "yellow ended" RCA cables) and S-Video. S-video just gives better color reproduction, but no more bandwidth.
VGA, DVI, HDMI, Composite, all will offer enough bandwidth for 1080p or better, and again offer better color reproduction.
thnx for the quick replies...just to test I got 1920x10xx in 1080i using the DVI connection...will go buy a component cable from a place with a good return policy and just test it. it was quite hard to look @ an explorer window in that high rez (lines waver), but am sure video playback looked better than s.vid and that's what I want it for....my tv only has one DVI and my ps3 uses that
am not changing the cable constanly to use DVI...the component cable works great, but instead I used media player 11 to share the movie DIR's I wanted, added the ps3 through it and I just streamed them through the PS3 instead. looks fantastic! no cable needed, taking the component cable back
waaaaay better now ...thnx for the input
