TV Motherboard White Component Sparks when TV Turned On
Hello,
When I power on my LED TV, I can see a white component in the motherboard producing a little light that resembles a spark with a faint audible sound. In [1], I show a picture of the component that produces the "spark" which I suspect to be a fuse. The TV does not start at all.
My questions are:
  1. Is the little white guy a fuse?
  2. What happens if I connect its two ends with a wire, will this fix any problem associated with it? I do not have enough soldering experience to actually remove it, and put in a new fuse.
Many thanks,
Amine.
[1] https://www.dropbox.com/s/7s77ohqyc0ithsj/Motherboard Fuse Maybe.jpg?dl=0
This is not a general electronics repair forum. This forum is for discussing PC Computer motherboards only, not for TVs.
I recommend asking your question on the EEVBlog forum in the Repair section linked here: https://www.eevblog.com/forum/repair/
If I'm reading that board correctly, that should be VDU1...not that that helps much. Variable diode, resistor? Could also be a component related to the VDU circuit?
looks like there is a hole in the center of whatever it is. GiGaBiTe you have any idea?
I agree with ryan_975, it looks like an LED.
Though the LED looks like it has the black spot of death, which could be why it is sparking/flickering. Either the LED was over driven for most of its life and died, or something hit it with a power spike and killed it.
I recommend removing it and replacing it, but for the OP I'd recommend finding someone who can do it for you, SMD soldering can be tricky.
