Domingo
- Jul 30, 2004
I did buy some Noctua Y-adapters, in case we needed them. But then it didn't seem like they would work for any of the additional fans. I assume this is what you meant by "grouped in 2's", right? They're simply wired together (in series? err parallel? I dont know which). I imagine I need to have only variables paired up with variables and the same for constant RPM/Voltage fans, right? You couldn't mix and match those fans on a splitter and get any sort of fan control. What about mixing and matching 2 different types of constant RPM fans? Like say the CoolerMaster 120mm and Phanteks 140mm on the same Y-adapter? Or should it always be identical models for spec reasons?
I actually originally had no plans to use the Phanteks, but my brother-in-law thought it would be better since they're bigger. I originally planned to replace both of them with 120mm CoolerMasters for a total of 3 Noctuas and 3 CoolerMasters. The CoolerMasters get great ratings online, but I realize that's in large part because they're $10 for 4 fans. I don't know what the Phanteks are rated or if they can even be purchased apart from the case.
I do also have room in my case for at least 2 more fans, but 1 would be partially blocked by the optical drive and the other would be mostly blocked by the HDD cage/tray. I don't honestly know if I need more anyway. It's a full-size case. I don't have a cover over the PSU. I don't have a dedicated GPU, and I'm using a stock CPU cooler/fan. So it's pretty open in there.
Yup, just using Y-connectors. They're the ones built into my case (Carbide 540) and they're identical 140mm fans stacked on top of one another. It was a pretty easy solution rather than connecting them individually. The fan controls seem to have no issue controlling them both, although I probably wouldn't mix and match.
