I thought it would be a cool idea to try out a record player because i have a lot of records that i was given. I want to buy a record player and keep it under $200. I can't spend anymore then that. I used misterx's tutorial and made my own interconnect for the player, so in terms of budget, thats taken care of. Can you guys recommend some players for this price range? Will these players sound decent? I don't need anything too saphisticated, just something of decent quality that can play records.
I am using a panasonic dvd player for the source of my system. Will i get good results by using the Toshiba SD 3950 instead? will it sound good with both my speakers and headphones?
thanks
thanks
