Turning on PC w/o a case?
Predator_CITF
I'm taking out the old components in my old Dell, and I am putting it in one of my cases I have lying around. Now...I can't find a place to plug in the PWR, Reset, HDD LED, and PWR LED plugs into the motherboard so that I can turn it on. Is there a way I can turn it on w/o having a button (the PWR switch on the case)? This will be powered by an Antec SmartPower 350W (20pin), btw.
the 2 pins on the motherboard that have/had the connector for the atx power switch connected to them have to be shorted, that is, use a flat blade screwdriver to touch both pins at the same time. if you get a tiny spark, dont worry. if you get a big spark, run away screaming "fire".
there's usually a group of pins near the bottom of the motherboard where you plug all those small wires into...just gotta figure out what goes where....sometimes they're labeled in very small letters so you can tell what is what....sometimes not....if they arent labeled then get the model number of the motherboard and try looking for the manual online?
The problem with a lot of Dell motherboards is that they are proprietary, meaning the little things like the main power connector or PWR LED HDD etc. are all non-standard, usually unlabeled, and nearly undocumented. :( It varies by models and families though, but you have an unnecessarily annoying road of case and switch inspection ahead of you.
Even a dell mobo is still turned on by shorting some pins. You just have to find out which ones they are :).
just don't short the wrong ones, cuz that can suck. you can fry something
i suggest maybe calling dell about it?
I've never fried anything shorting random jumpers trying to find the right one . Usually I do it only on older computers, but I've never had a problem FWIW. Not on the whole mobo of course, just on the front panel connectors :).
Same here. I picked up a slot1 P3 with a board recently. When it came to turning it on, I just started poking pins with a screwdriver till something happened :p
I build complete systems every day outside the case, mainly because its an easy way to test components (too many times assembling in the case only to find a bad mobo). By bridging (shorting) the two pins with a screwdriver you are essentially acting as the switch does: no worries about frying something. What Neurofreeze said was dead on about the proprietary stuff, you'll just have to find the right pins. Usually they are side by side, so think of it kinda like running a stick along a picket fence....if all else is connected correctly it WILL turn on just fine.
So all I have to do is plug in the power supply to the motherboard, plug the PSU into the wall, and then just take a screw driver, and keep touching pins and if i touch the right one, the PC will magically turn on? And if I do turn it on, can I let go of the screw driver or do I have to keep it holding on?
You can let go of the screwdriver. Holding it there would be the equivalent of holding the power button. You dont have to worry about shorting anything, Ive never heard of any case where something shorted from short switching pins.
Well the shorting method worked on my ECS motherboard (whose AGP port is broken) and this motherboard was dipped in boiling water too. But when I plug in the PSU into my Dell motherboard and switch the button to on (on hte PSU), I hear a weird noise coming out...is the Dell motherboard dead or wut?
like a poster mentioned previously in the thread....most of the dell motherboards/powersupplies used in systems over the last 5 or even 10 years are proprietary. This means that it will most likely not be just as easy as randomly shorting pins to power on the board.
And if you tried to plug a regular psu into that dell motherboard there is a pretty good chance you fried the motherboard, or psu or, various other things you had attached to the system.
Dell does not provide this info to the public (pinouts and wire diagrams) to prevent people from doing exactly what you are trying to do. I've been down this road with spare dell parts tons of times.....just salvage what you can and ditch the dell mob/psu. Its not worth the time and effort.
*What ATX said^^^^^^^^^^^^^^^^^^^^^^^* To the OP no, don't hold the screwdriver there, it will run without it. When you're done simply unplug the PSU.
Dudes tools like that are to take advantage of noobs. Like the $10 thing to turn on your power supply without mobo, where a paperclip works fine.
Since they are usually to the left and right of one another, I also like the run it across ("stick on a picket fence") approach. Tool won't help him know which ones are the right ones anyways. Hell knowing that this might be just as safe.
