Turned on comp today. Wont POST. Crap......
wedoe21
So i have an asus p4p800 deluxe. (the rig in my sig) I turn on the comp today, it worked fine 2 days ago, and it doesnt even post. I get the startup beep, then a short while later i get a second beep. I try restarting it a few times, same thing. So i pull the CMOS battery and let everything sit for a while then start it up again. It turns on gives me the initial beep, then 4 quick beeps. I checked to codes here, http://bioscentral.com/beepcodes/amibeep.htm .
1 short DRAM refresh failure The programmable interrupt timer or programmable interrupt controller has probably failed
2 short Memory parity error A memory parity error has occurred in the first 64K of RAM. The RAM IC is probably bad
3 short Base 64K memory failure A memory failure has occurred in the first 64K of RAM. The RAM IC is probably bad
4 short System timer failure The system clock/timer IC has failed or there is a memory error in the first bank of memory
So i pull both the ram sticks and try them in every which way and i get the same results. WTF happened? Suggestions please.
are you saying you tried new sticks? It sounds like a ram problem...someone should be able to help you better than i can
Are you getting any audible messages from the motherboard (via the speaker output on the MB)? I had the same MB I just replaced, and I was getting a message "System failed CPU test" when my system died.
ya its the motherboard speaker. I just tried it without any ram and now im getting a long short short beep code.
1 long, 2 short Failure in video system An error was encountered in the video BIOS ROM, or a horizontal retrace failure has been encountered
1 long, 3 short Memory test failure A fault has been detected in memory above 64KB
1 long, 8 short Display test failure The video adapter is either missing or defective
Are the beep codes on that list i linked right? Shouldnt it be a long with 3 shorts with no ram. Why am i getting a video error without ram installed?
Sorry, I should have been a bit more clear in my description. I meant the speaker output jack from the MB's sound card (where you connect your external speakers or headphones).
Keep your speakers on (or headphones plugged in) while you attempt to boot the system. You may get a verbal message that could help you pin down the problem.
BTW, if you getting random errors about various components failing, but the beeps don't repeat, I would initially suspect the power supply.
When I put on the headphones the voice said VGA error. I restarted it and got the same beep code but no voice. Its kind of weird that it said it only once, but does this mean the the motherboard is fried? I think the board is 2 years old. Anyone know how long ASUS's manufacturers warrenty is?
I tryed two video cards so its not the card that is the issue. I googled around and i think the warranty length is 3 years. I'll call them on tuesday.
CRAP. So i put in the new PSU. The only thing hooked up is the RAM and CPU. When i turn it on i get no beeps or errors. I put in the video card plug in the monitor, turn it on, and i get a "failed VGA test" ERROR. What the hell? Is the VGA port fried? Could i use a PCI video card to get around it?
Well it looks like the dying PSU took my viedo card with it. I put in that old vga card that i tried yesterday when the psu was dying (i got the error with both cards yesterday) and it seems to boot fine ill log in and see if everything is working. Thanks for all the help guys.
