Turned Antec P180 Mini into super cooler
dkev
The Antec P180 mini is flat out the best micro atx case going. But for all its pros it is not a gaming case. At least not out of the box. With a few simple mods I was able to get this case to cool the system to ambient temperatures idle and only 6-9 degrees over ambient under full load. CPU temps were reduced to 27c under full load. I was using a CM Scout. It's a great case but it didn't cool nearly as well as the 180. I think the Antec 200mm fan makes the difference. I use a Corsair H50 with a CM R4 and fan shroud mounted outside the case in a pull config. I have white fans on order and will be changing out all the 120 system fans with the new ones.
I completely removed the cages and cut a way all the steel mesh for the fans. I also cut blow holes in the side panel to increase cooling for the vid card. The cooling performance was far better then I anticipated.
Cool man. Seems like it was a lot of work. :D But defiantly worth it for the lower temps.
27C under full load? Not even my water cooling setup with 2 triple rads idles that low....
Just curious, what defines a "gaming case"? Lots of fans? My P180 has a total of three fans for case airflow (and 2 on radiator for the CPU) all at 5v, but I do plenty of gaming and overclocking.
Not really liking the fans on the side but function>form always :)
Well the side fans will look better once I put the white ones on. As far as cpu temps. I have a Phenom 550. While it is overclocked 1ghz, it doesn't generate a lot of heat to start with. To me a gaming chassis provides ample cooling to the the video card. Which the P180 does not out of the box. Nor does it provide decent cooling to the HDD IMHO. So these minor mods correct the case's deficiency's.
