irishBoiler
- Feb 29, 2008
Subject pretty much says it all. I have a 2wire wireless dsl router (it has 4 ethernet ports + wireless) in one room. I have an xbox and xbox 360 about three rooms over and I have a WRT54G v6 router laying around. Is there a way to use the linksys as a bridge so i can put the linksys in the same room as the xbox and wirelessly bridge the connection between the linksys and the 2wire?
I've looked at dd-wrt, but they don't really support v5 or beyond. They say there's a dd-wrt micro, but you will probably brick the router.
Naturally, in these times, I'm looking for a no/really low cost solution. Also, the wireless adapter for the 360 isn't an option as the usb port on the back has fried, post-warranty
