turn a db9 null modem cable to straight through?
Typically pins 2 and 3 are the transmit / receive on a DB9 (actually DE9) RS-232 serial cable.
The following connections are required:
Pin 2 (transmit) on end "A" to pin 3 (receive) on end "B"
Pin 3 (receive) on end "A" to pin 2 (transmit) on end "B"
Pin 5 (ground) on end "A" to pin 5 (ground) on end "B"
The following may or may not be required:
Pin 7 (request to send) on end "A" to pin 8 (clear to send) on end "B"
Pin 8 (clear to send) on end "A" to pin 7 (request to send) on end "B"
Many times pins 7 and 8 are connected together on each shell end instead.
