Turion Power Control
Brother John
At one time I was told that it will work to lower the voltage on my F socket CPU's to lower the power draw.
If this is true will these instructions have the right packages for F socket on Ubuntu 10.10, it is listed for G34.
TPC will work with your chips.
There is a PDF included with the .zip, will give you the info you need to under-volt.
Documentation is known to be inaccurate in many areas.
First, disable PowerNow; then...
...make sure to use tpc-0.44-rc2 and...
...discover your current settings...
Code:
sudo tpc -l
And go about:
Code:
sudo tpc -set vcore <value>
sudo tpc -fo 1
sudo tpc -fo 0
