TuniqTower120
Im so glad I waited for this cpu cooler. My Temps of e6600 according to Core Temp Beta 0.94 are idle-core0 29C core1 27C, load-core0 35C core1 33C. I have 2 top 120mm exhaust, 1 side 120mm exhaust, 1 front 120mm intake, 1 rear 120mm intake, Lian Li PC-V1000B PLUS II case. So far IMO this is the best aircooler ever made to date! Also this is stock, im not overclocking yet!
So you are able to fit the TT120 in a Lian Li PC-V1000B PLUS II case? I have a Lian Li PC-V1200A PLUS II and an evga 680i MB and my TT120 will not fit in the case, it hits the wall dividing the area where the PSU is mounted long before I get the mother board back to where it needs to be to mount it back in the case.
Try mounting the cooler with the motherboard tray inserted into the case. The case itself probably isn't causing any clearance issues.
I'm not sure what you mean (the tray doesn't come out of the case). The cooler mounts with a back plate on the board, so I have to take the board out to mount the cooler. The cooler hit the case, needing to go over another 1/3 to 1/2 inch before the mounting holes line up. Maybe I'm being a bit too timid with my not wanting to force the board into place but I'd rather not damage a $250 board because a $50 cooler doesn't fit the case. :)
Sorry, I misunderstood the wording of your post. Too bad that it doesn't fit in your case(unless you're willing to mod it, of course...).
Great cooler, I can run my E6400 @ 3,600Mhz 6 hour Orthos stable with it. On scorching Puerto Rican ambient temps.
Here are some quick pics, now that the rig is together and everything works, I gotta cleanup the wires, benchmark, and oc the cpu. The heatsink is square so you can turn it anyway you want to, my is turned to blow air from the cpu towrds the 2 top exhaust fans and the rear intake brings in fresh cold air right infront of the cpu cooler which is great!
Nice pics, what are your fan speeds set at with that config? When I lap my tuniq/IHS I plan on reorienting it the way that you have yours, with it drawing air in from the video card side and exhausting toward the top where my PSU and 1x 120mm exhaust is. I just don't understand much about fan speeds and airflow so I have all mine on full blast right now (Stacker CM830, 1x top exhaust, 1x rear exhaust, 2x front intake, 3x side door intake)
Some pics at night, the only fans at full speed are the tuniq fan, and rear intake fan, the rest are on half speed with the front fan controller. Sry bout the blurry things, camera has a fit with night pics and motion. So yes the tuniq tower fits the case without any mods, you just turn it to the side instead of up or down, so it works out well!
mines doing 28c on idle on my lapped (man the IHS was REALLY bad) 28B 6600 :).. havent overclocked it yet but cant wait to see the results
