Ok, so I bought a tuniq tower 120 thinking that it would drop the temps of my e4500 cpu overclock, but it doesn't seem to be the case. My overclock is @3.2Ghz with a temperature ranging from 62-64C at load with a voltage of 1.41~. From all account I have read is that the voltage isnt terribly high, but the temps are. So I am not really sure what is going on, since I have read of much much higher overclocks on stock intel coolers.
One idea that I have is that the cooler isnt set right, I am thinking that since I wasn't sure how much I should screw down the screws + I am able to wiggle the cooler around with my hand if I want. I guess I am wondering(since it didnt say in the directions) How far should it be screwed down, and should it wiggle at all?
Thanks for any help or suggestions.
