..is awesome. That is all.
Dropped my idle temps by 10 degress with the fan rheostat on high - smart controlled (900RPM). And 5 degress with it on low - smart controlled (400RPM)
Dropped load temps by 15C at low - smart controlled (900RPM) and by a whopping 20C with it on high - smart controlled (1800RPM).
It's also just as quiet, maybe even quieter, at full blast than the stock heatsink.
One question though. I noticed my vdroop wasn't nearly as bad as it was with higher temps. Does heat = more vdroop? I was able to lower my core voltage in bios by .02 and maintain the same voltage under load as I did before.
