Tuniq 120 Fan Control
CalvinGT
Stupid question about the 120. Where in the world does the little attachment you can put in a PCI slot plug into the motherboard to control the fan speed? I have been trying to figure this out for a week at least, and it is driving me nuts-google has not solved my mystery. If that is not the most efficient way of doing it, whats the most reliable software to manipulate fan speed? Noise is not an issue for me, I simply want to make my system as cool as possible.
Thank you!
Hi the little attachment on the fan controller fixes on to the two pin on the fan. A good software for fan control is Speedfan. Just google.
Thanks umgill. Since my case is so insanely crowded right now I don't want to try to unplug anything to get that control in until I move, I will try speedfan for fan control. Thanks!
Ok so here is my problem-speed fan only shows one fan-does it only detect the CPU fan and not the northbridge fan or anything else? I have all the fans on my Antec 900 manuall set to 100% so its not a big deal. Either way, speedfan seems to be reading my Tuniq at 100%, which is what I wanted in the first place, just wanted to make sure it was supposed to only show one reading.
thanks!
