Budwise said:no, 1/2" OD will prolly not work as the ID will be too small. I am running the tubing you are referring to and it is good stuff. Masterkleer![]()
sonnybobiche said:Temperature-wise it would be res->pump->rad->cpu
autobot said:After a few minutes of operation the coolant in your watercooling system reaches an equalibrium. Realisticly, the only thing that matters in the arangement of components in your watercooling setup is that your resevoir or t-line is in front of the pump. I suggest you route the tubing to your WCing components so that you use a minimum of tubing and use as few sharp bends as possible. As for tubing itsself, I always use 7/16"ID 5/8"OD MasterKleer from McMasterCarr. Great clear stain-resistant tubing that is only $0.38 per foot. I always make 20 foot orders and its $12 shipped.
qbackin said:Res in front of the pump?
