I'm not new to watercooling however, I never used a GPU loop before. I plan to get the EK full coverage block for the 4870x2 and most of the pics I've seen of wc setups have smaller diameter tubing as opposed to their cpu loops.
Wondering if 1/2" 3/4od is ok for a GPU loop. Or do I need to go smaller? Also are the threading spacers necessary for the GPU block Inlet/outlets?
Will be going with a 1x120mm radiator and a Laing 350 10-12 watt Alphacool acrylic top pump.
