Tubing Question
Darkatom
Please bare with me as im a tube noob :) . My Swiftech H20 Ultra Kit came with 8ft of 7/16" ID (5/8" OD) tubing. Now since i will be relocating my rad soon, I am deciding to go with some tygon tubing that I've heard so many good things about. I found this one over at frozencpu.com .
http://www.frozencpu.com/products/2...ti-Kink_12_ID_58_OD_Tubing.html?tl=g30c99s172
Is this the correct size that I should be looking at, oh and the Apogee GTX i'll also be getting states that it has 1/2" chrome plated barb fittings. So is that the correct size of tubing for me. Thanks.
yup good to go
Yup. Nice tubing. Pricey, but clear. Doesn't bend any better than Clearflex or Masterkleer though, just more clear.
masterkleer IS the 7/16" ID 5/8" OD tubing, incase you wanted to know...
Tygon and masterkleer look ALOT different, so I'd get the MK stuff to keep with the loop continuity.
I ended up ordering 8ft of the tygon so I can just replace the whole loop.
