hey all, im getting a storm kit and i need to buy some tubing for it. this means 7/16" ID x 5/8" OD
secondly, should i get 10? 15? 20? ft of tubing? i need to run to the rad, pump, res, cpu and gpu blocks
so far my top choice seems to be:
tygon
now possible alternatives would be an even better, longer lasting, kink proof tubing if it exists. also if possible i wanna explore the possibility of getting black tubing which would save me the cost of having to pick up an alernative coolant to replace the hydrx which is green.
thanks all!
tygon
thanks all!
