Tubing Issues and selection required for HIGH FLOW system.
kleox64
Got my legris samples and I will not be able to use 14mm OD fittings as the 1/4" BSPP to 1/2" BSPP adapters are to big to install on the maze 4 GPU blocks. This leaves me with only 12mm OD options.
Tubing options are as follows:
12mm OD/10mm SEMI-RIGID NYLON (natural, cloudy, translucent etc...)
12mm OD/8mm ID POLYURETHANE POLYETHER (CRYSTALL, clear as tygon)
also ive found PVC 12mm OD/9mm ID which is the largest ID available for the required OD. Anyone who can obtain high quality 12mm OD/10mm ID PVC tubing pm me ASAP.
Bear in mind the watercooling system was as before:
Storm G4
BIX III
MAZE 4 GPU LP SLI
MAZE 4 CHIPSET
EHEIM 1250
HD block
kleo
