Hi guys..
I have a quick question.. I am using a Swiftech Apogee Gt block (1/2" barbs) and 7/16" tubing.. It took some elbow grease getting the tubes on the barbs of my other components.. Do you guys recommend installing the tubing on the CPU block outside of the case and then mount it on the mobo? I only ask cause I am a bit squeamish using that much pressure on the mounted block w/ the cpu (e6750 on DS3R) underneath it..
Apologies if this is the noob question of the century but this is my first component by component installation of watercooling..
Thanks !!
Thanks !!
