Tubing! Help!
Mr. Scary
anyone know where i can get some 1/2"
UV PURPLE tubing????
i don't really want to settle for blue! and i don't want to do the dye thing!
i'd like some decent quality without breaking the bank, but if it's purple i'll pay a bit more to find it. also, i'm using koolance 1/2" compression fittings so i don't think that the thicker of the two "OD" sizes is gonna work.
any help, or thought would be much appreciated!
M$
I would say... good luck finding a purple color. A quick check on performance-pc shows no purple tubing, and in my experience, they tend to carry almost anything and everything related to cases, cooling, water cooling, etc.
Ummmm,,,,phroz,,,,so yer dissin' me for, "askin' around"????
btw, thanks for the reply :)
i so appreciate it!!!
Man,,,,,i can't change up the fittings i have to go 3/8", although i guess i should've looked at the end result in determining how the 'color' scheme play's out.?.?.?.... i just can't believe that there is that much of a selection decrease in goin' the 1/2" route!?!?!?!???????
kinda friggin' whack,,,,huh?
M$
Have you considered using dyed water? I don't personally like water dyes, as most people will mention that it stains, but it's not that harmful if you really want that UV purple look. You can pair UV purple water dye with any clear tubing and get your effect.
thanks shiny, for the response.
i've been torpedoe'd with serious reasons for NOT using dye's or dye bomb's.
enough so that im' going to use distilled water and silver.
any personal exp on the above or whatever?
tx
M$
holy crap, you are the 'King'!!! LOL!@!!!!!!!!
is that UV by any chance????
LOL!!!!!
thanks bro for the response!!!!!
M$
LOL!!!!!
M$
No I don't think it's UV, but good luck finding 1/2 ID purple tubing, in general, anywhere else. :D
LOL! i hear ya!
so seriously, have you used and or seen that tubing?
how is it to work with? kink? what?
thanks again for the response bro!!!
M$
ps-leave it to a racer, huh? i should've known, given the nos crap i've gone thru, huh?
LMAO!!!!
g
Hmm... that looks like automotive tubing, so it should be fairly flexible without kinking too much. In my experience, that's the way they are (my dad is a mechanic). 25 feet for $8 is a pretty good price, considering most tubing rated for computers is well over $1.50 per foot.
Edit: ummm... a quick google search on convoluted tubing shows that it is designed to protect electrical wires. Not sure it would be up to the task of handling a water system. Most likely it would be too weak to handle the pressures.
IF you can get it for that!! it's more like $1.79-$2.50+.
i'll start to look a bit at the 'bigger' picture and expand my search(ing/es).
Thanks again, for the heads up guys!
M$
Hehe, convoluted tubing is NOT what you want. It's split down the entire length. Designed to wrap over the outside of wires. You could certainly wrap it over the outside of regular water tubing but I'm not sure that's the look you're going for.
Have fun.
steve
ummmm, well, again, thanks for the input.
as for the years, i'm probably older than you, but who knows.?.
'64 was a very good year, just ask me,,,i'll tell ya!
M$
writing the way you do makes whoever has to read it loathe you, and makes yourself look like you do not even have the capacity to type any sort of a meaningful complete sentence. i either hate you or feel sorry for you, not sure which, but thought you should be made aware.
Well, thanks for the heads up, ghost.
If you don't like the read, or the thread nobody's asking you to stick around!
Last check of the thread, i didn't see you putting any positive or productive information into the conversation.
As for the others chiming in, again, thanks for the input, suggestions, and help. My apologies if the puncutation has offended you or made my post/responses hard to read!
M$
