Tubing Diameter
Sphere
Hi Everyone,
I have everything I need for my first water endeavor, the ID is 3/8, now I haven't been able to find what the outer diameter should be.
Exactly what's the purpose of a thicker or thinner OD? and how do I decide what size I should be using?
Also, what would be the recommended hose clamps that you would suggest?
Thanks
Hey, you can go with 1/2" OD or 5/8". If you go with 5/8" you might get better bend radius but be sure that it's soft PVC like tygon or primoflex. I'd personally would go with 1/2" since it's more standard and it'll be less bulky, and the bend radius is pretty good. The other advantage of 1/2" OD is that you can use it with compression fittings.
For clamps go with these:
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=298&products_id=3802
