videogamer323
- Jan 31, 2003
What do you think about this tubing?
I'm leaning towards the 1/2" I.D. x 13/16" O.D. x 5/32" Wall Clear PVC Tubing 65 PSI for the thicker wall, which should mean less kinks on sharp bends. Also I won't touch 7/16" ID tubing ever again... shit is so hard to work with.
Also I have been doing a lot of reading and it seems the best additives would be PT Nuke and Distilled Water for the mix if everything is all copper. My question is, do the Laing D5 series pumps have any metal inside that is exposed to the water or is it just plastic (like) materials.
Thanks in advance
Thanks in advance
