Tube Reservoir?
Spazturtle
I'm not sure about matx cases, but tube res' s aren't hard to mount. I have mine in my case only being held in by fittings. One sli fittings connecting it to the pump directly delow it and an assortment of fittings connecting it to a rad. Most also come with half circle clamp like mounts to help with mounting. I use to have one mounted to the top of a case screwed Into fans on a rad use the clamps and it never even moved. As long as you get one that will fit you should be fine. You could also look into the pump/res combos that people like EK offer where the res is attached to the pump and direct feeds it.
