Tube Cleaning Brush
Go to a smoking store or a craft store and buy pipe cleaner.Much cheaper.I used to get a blower and a napkin and blow the napkin through each tube.
Go to you nearest aquarium store and ask for some tube brushes. I think a set goes for under $10 USD.
I have a brush that I used to use to clean my trumpet that looks exceptionally promising.... I might just do tht when I get a graphics card block...
Tubing from McMaster is pretty cheap, you could be lazy and just replace all of it for not much money.
This man speaks the truth.
