TT Tsunami front door mod
headala
Now, I'm thinking it may be easier to switch the side panels along with the mobo tray (non removable) and back of the case, sortof like one of the LianLi BTX-style cases. Anything I should know about before I begin?
Thanks!
Original post:
Hey, folks. I'm thinking about how I don't like the way that the front door on my Tsunami Dream swings to the left, the same side as the window. I'd really like for it to swing to the right, though.
Do ya'll think it's possible to reverse the front door? You'll see what I'm talking about here . It seems like I would need to reverse the whole front assembly, which is the aluminum outer door and the plastic inner door. That means I would have to cut out the middle of the inner door and replace it with plexi; no problem.
Question is, do you think it would work/fit right? Probably have to mod the locking mechanism, etc. Any other things?
Thanks.
