Guys who own a TT Lanbox, can you tell me what type of cooling setup you're using?
Do you have all three fans in the back, plus which way are they going (in/out) and the front 80mm fan... in our out? I'm thinking of reversing my airflow (from front -> back) because I have a really hot 4850 and Phenom 9950 up there that are hitting some high temps. My Phenom with the 8700CNPS NT is hitting around 59c after 15 minutes on prime 95. I'm using IC Diamond 7, and that's a REALLY high temp. It's the same as the stock cooler, so my first idea is the air cooling isn't doing jack schitt.
