Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well the straps that go around the height of the case will fit because I have a X-Superalien case and it fits. That case is 539mm tall and the tt is 530mm tall. Don't know about the strap that will fit around the depth of the case. Alien is only 483mm in depth in comparison to 560mm for the TT. It may fit because there is some extra strapping left on it when you losen up the clip or whatever you call it.
I hope you don't base your mobo buying decision on the pc carry bag... if so that would be um... stupid. Get the mobo... if the carry bag doesn't fit oh well... sell it.
but i cant sell it here,, since i am buying it from overseas,, and nobody here know anything about these stuff(they say DFI,, what DFI) let alone a bag for a PC what tha just curry it your self they say..!!!
Haha then you can overcharge for it if no one knows what it is or what dfi is... when you show it to your pals they'll be in amaze and say I'll take if for 10 cows!!!
I have the Armor and a DFI LanParty 875pro Rev.b with the "case bag(handler?)" and it fits but I have never trusted it just by the top handle, my box is about 65 pounds too
