Tsunami va3000 case - water cooled
Its quite possible with a little modification. Although I havent seen a watercooled Tsunami, I own a Tsunami and there is plenty of room for watercooling.
Do you think an internal solution would be possible (such as a Danger Den kit where the radiator is inside the case?
